Hello everyone,
Does anybody have experience in running lammps on Windows XP? I have compiled lammps to run in a Windows XP machine with 2 Intel Xeon processors. Is there a way of actually using the 2 processors in my run?
thanks
Jaime
Hello everyone,
thanks
Jaime
Hello everyone,
hello jaime!
are you certain that those are two real processors and not
just a single processor with hyperthreading? in the latter
case there is no gain in running in parallel (for which you
just have to compile an MPI library and compile lammps with it).
cheers,
Yes. I use cygwin on top of Windows XP and run LAMMPS on my box’s 2 procs. Check out cygwin at: www.cygwin.com
Paul
Hi Axel,
Yes. There are two processors physically available. I’ll try Paul’s suggestion with Cygwin.
thanks
Jaime
Hi Paul,
I have installed cygwin with all the packages available, but when I used “make cygwin” I got the following error
mpicxx: command not found
how can implement mpi in cygwin?
thanks
Jaime
Hi Paul,
"make cygwin" I got the following errormpicxx: command not found
by downloading and compiling an MPI implementation (if
not precompiled versions exist, that is).
e.g. the one from http://www.open-mpi.org
or the one at http://www.mcs.anl.gov/mpich/
cheers,
Jaime,
Download and install mpich2. You should be able to find it by googling for it.
Paul
