After compiled LAMMPS w/h MEAM potentail, I tried to test it using exmaple files at example directory.
But I got following error:
./lmp_nano: error while loading shared libraries: libmpich.so.1.0: cannot open shared object file: No such file or directory
What does it mean?
How do I solve this libmpich.so.1.0 error?
Thanks.
HeeSung
What does it mean?
that you either didn't install mpich properly or
didn't use mpirun correctly. this is not a LAMMPS problem
and you can get a lot of useful information by sticking
this error message into google.
by understanding how shared or dynamical libraries work
and then taking the corresponding countermeasures (e.g.
fixing the installation or setting LD_LIBRARY_PATH or
whatever else may be needed).
have a look at, e.g.,
http://www.dwheeler.com/program-library/Program-Library-HOWTO/x36.html
cheers,
Thank.
Does it mean that I have to compile LAMMPS again?
Thanks.
HeeSung
Thank.
not necessarily. only if you'd recompile mpich to not
use shared libraries. in many cases putting the missing
library into a directory that is searched by the dynamical
linker or setting LD_LIBRARY_PATH appropriately should
do the trick.
cheers,
