I have a question about the velocity command
If I wrote
velocity group set 1.0 NULL NULL
run 100
run 100
Does the velocity set command still work in the second 100 run?
Thanks in advance.
Fengchao Wang
2010-01-13
run 100
run 100
Thanks in advance.
Fengchao Wang
2010-01-13
Velocity set (or create, etc) is a one-time
operation, that works when you issue it. Each
run will change the velocities (presumably).
