[lammps-users] segmentation fault. signal 11
Dear users, thank you for your concern.
I asked about the reasons of the segmentation fault error.
I calculated system with 260000 number of atoms and got no such error.
In PBS script I used pvmem=850mb.
uname -m
x86_64
/mpich-ch_p4-gcc-1.2.7
/cat/proc/cpuinfo
processor : 3
vendor_id : GenuineIntel
cpu family : 6
model : 15
model name : Intel® Xeon® CPU 5160 @ 3.00GHz
stepping : 6
cpu MHz : 1998.000
cache size : 4096 KB
physical id : 3
siblings : 2
core id : 7
cpu cores : 2
fpu : yes
fpu_exception : yes
cpuid level : 10
wp : yes
flags : fpu vme de pse tsc msr pae mce cx8 apic sep mtrr pge mca cmov pat pse36 clflush dts acpi mmx fxsr sse sse2 ss ht tm syscall nx lm pni monitor ds_cpl est tm2 cx16 xtpr lahf_lm
bogomips : 5985.04
clflush size : 64
cache_alignment : 64
address sizes : 36 bits physical, 48 bits virtual
power management:
2010/12/20 t t <[email protected]...>:
why restricting the memory?
i ran your input after setting all run statements
to "run 2" and dump statements to output in every step
and it ran through (using two tasks on a 32-bit machine).
the issue has to be either how you run the job or in the
physics of your system.
no lammps issue in sight.
