I have lammps on both my linux ubuntu laptop and on my university account. My ubuntu lammps (both serial and parallel) work well, whereas the same input/data files produce a segmentation error when I use lmp_serial (Dec18_2010 version) right in the beginning of the simulation.
Does anybody have suggestions as to how I could overcome this serious problem; I understand that it is an OS problem and usually difficult to solve and I do not really know from where to begin to tackle the problem?
Thank you!
Anna
segmentation faults can have many reasons. the first thing that you can
do, is to try and find out _where_ it happens, and whether it is due to a
bug that was already fixed since.
to find the location of the segfault, you can just run lammps with the help
of a debugger, e.g. gdb.
gdb /path/to/lmp_serial
then on the gdb prompt you type:
run -in my_input.in
and then wait for the segfault.
when this happens, you can type:
where
and you get a stack trace and that will indicate the location of
where the segmentation fault happens.
the alternative to this is to generate a core dump:
first type: ulimit -c unlimited
then run lmp_serial as usual. after it crashed, you should
see a file core.#####. again, you can use gdb to investigate:
gdb /path/to/lmp_serial /path/to/core.####
and then:
where
and you get a stack trace again, telling you the location
(function name) of the problem.
and then you double check with the current version of lammps.
cheers,
