Hi all,
Is there any way i can set the 1-4 weighting coefficients for individual dihedrals? I have both electrostatic and vanderwals interactions in my system. The special bonds command sets it for all the dihedrals at once but what I am looking for is the ability to set it for each particular dihedral. Please let me know if anyone knows a way around it.
thanks.
Hi all,
i would exclude 1-4 interactions completely in special_bonds
and then use a dihedral style that includes the charges in the
calculation. this way you can turn this into a per dihedral property.
if this kind of dihedral style doesn't exists, you need to write one.
cheers,
The only force field I know that is defined similar to this way
is CHARMM. LAMMPS has pair lj/charmm/coul/charmm (or long)
that lets you define the sigma_14 and epsilon_14 for individual
1-4 interactions. This in is conjunction with dihedral_style charmm.
If that doesn't do what you want, you'd have to add your own customized
pair style.
Thanks, Steve and Axel for your suggestions.
I had couple more questions regarding dihedrals and impropers.
As i understand it, the special bonds command sets the weighting for non-bonded interactions between atoms connected through an improper also. If an improper dihedral is ordered i-j-k-l and i-l end up being bonded (as 1-2 neighbors) then non-bonded interactions between i-l is weighted by the 1-2 weighting coefficient in special bonds command. Is this correct?
For improper style harmonic (assuming the improper is ordered i-j-k-l), the angle computed is the Wilson-out-of-plane angle between the plane of i-j-k and the plane of j-k-l. This is same as the angle that is computed in improper style cvff. Is this correct?
thanks in advance for the help.
Comments below.
1. As i understand it, the special bonds command sets the weighting for
The non-bond weightings pay no attention to diherdarl/improper topology.
Only to bond topology. So if I-J are bonded directly, that's a 1-2, no
matter what diherdarl/improper it might appear in.
2. For improper style harmonic (assuming the improper is ordered i-j-k-l),
You'll have to look at the formulas on the doc page for these 2 improper
styles. if that isn't clear, I'd suggest a CVFF paper. Or the source code.
