[lammps-users] several polymers
Dear Dr Kohlmeyer,
This is what I when I type the command:
:~/Desktop$ vmd -dispdev text -e simplexyztodata.tcl
rlwrap: Command not found.
Info) VMD for LINUX, version 1.8.7 (August 1, 2009)
Info) http://www.ks.uiuc.edu/Research/vmd/
Info) Email questions and bug reports to [email protected]...
Info) Please include this reference in published work using VMD:
Info) Humphrey, W., Dalke, A. and Schulten, K., `VMD - Visual
Info) Molecular Dynamics', J. Molec. Graphics 1996, 14.1, 33-38.
Info) -------------------------------------------------------------
Info) Multithreading available, 8 CPUs detected.
Info) Free system memory: 7764MB (96%)
Info) No CUDA accelerator devices available.
can't find package topotools 1.1
2.5
Info) Using plugin xyz for structure file chain.xyz
Info) Using plugin xyz for coordinates from file chain.xyz
Info) Finished with coordinate file chain.xyz.
Info) Analyzing structure ...
Info) Atoms: 11
Info) Bonds: 0
Info) Angles: 0 Dihedrals: 0 Impropers: 0 Cross-terms: 0
Info) Bondtypes: 0 Angletypes: 0 Dihedraltypes: 0 Impropertypes: 0
Info) Residues: 11
Info) Waters: 0
Info) Segments: 1
Info) Fragments: 11 Protein: 0 Nucleic: 0
0
atomselect0
Info) Determining bond structure from distance search ...
Info) Bond count: 10
invalid command name "topo"
Info) Atoms: 11
Info) Bonds: 10
Info) Residues: 1
Info) Waters: 0
Info) Segments: 1
Info) Fragments: 1 Protein: 0 Nucleic: 0
Info) Exiting normally.
and this when I do the following:
:~/Desktop$ vmd -dispdev text -e twochainsfromone.tcl
Info) Free system memory: 7758MB (96%)
2.5
Info) Atoms: 11
Info) Bonds: 0
Info) Residues: 11
Info) Waters: 0
Info) Segments: 1
0
atomselect0
11
22
1
atomselect1
name type radius resname mass x y z
{A A 0.8500000238418579 CHA 1.0 0.0 0.0 -5.0} {A A 0.8500000238418579 CHA 1.0 0.0 0.0 -4.0} {A A 0.8500000238418579 CHA 1.0 0.0 0.0 -3.0} {A A 0.8500000238418579 CHA 1.0 0.0 0.0 -2.0} {A A 0.8500000238418579 CHA 1.0 0.0 0.0 -1.0} {A A 0.8500000238418579 CHA 1.0 0.0 0.0 0.0} {A A 0.8500000238418579 CHA 1.0 0.0 0.0 1.0} {A A 0.8500000238418579 CHA 1.0 0.0 0.0 2.0} {A A 0.8500000238418579 CHA 1.0 0.0 0.0 3.0} {A A 0.8500000238418579 CHA 1.0 0.0 0.0 4.0} {A A 0.8500000238418579 CHA 1.0 0.0 0.0 5.0}
{A A 0.8500000238418579 CHA 1.0 0.0 0.0 -20.0} {A A 0.8500000238418579 CHA 1.0 0.0 0.0 -19.0} {A A 0.8500000238418579 CHA 1.0 0.0 0.0 -18.0} {A A 0.8500000238418579 CHA 1.0 0.0 0.0 -17.0} {A A 0.8500000238418579 CHA 1.0 0.0 0.0 -16.0} {A A 0.8500000238418579 CHA 1.0 0.0 0.0 -15.0} {A A 0.8500000238418579 CHA 1.0 0.0 0.0 -14.0} {A A 0.8500000238418579 CHA 1.0 0.0 0.0 -13.0} {A A 0.8500000238418579 CHA 1.0 0.0 0.0 -12.0} {A A 0.8500000238418579 CHA 1.0 0.0 0.0 -11.0} {A A 0.8500000238418579 CHA 1.0 0.0 0.0 -10.0}
{A A 0.8500000238418579 CHA 1.0 0.0 0.0 -5.0} {A A 0.8500000238418579 CHA 1.0 0.0 0.0 -4.0} {A A 0.8500000238418579 CHA 1.0 0.0 0.0 -3.0} {A A 0.8500000238418579 CHA 1.0 0.0 0.0 -2.0} {A A 0.8500000238418579 CHA 1.0 0.0 0.0 -1.0} {A A 0.8500000238418579 CHA 1.0 0.0 0.0 0.0} {A A 0.8500000238418579 CHA 1.0 0.0 0.0 1.0} {A A 0.8500000238418579 CHA 1.0 0.0 0.0 2.0} {A A 0.8500000238418579 CHA 1.0 0.0 0.0 3.0} {A A 0.8500000238418579 CHA 1.0 0.0 0.0 4.0} {A A 0.8500000238418579 CHA 1.0 0.0 0.0 5.0} {A A 0.8500000238418579 CHA 1.0 0.0 0.0 -20.0} {A A 0.8500000238418579 CHA 1.0 0.0 0.0 -19.0} {A A 0.8500000238418579 CHA 1.0 0.0 0.0 -18.0} {A A 0.8500000238418579 CHA 1.0 0.0 0.0 -17.0} {A A 0.8500000238418579 CHA 1.0 0.0 0.0 -16.0} {A A 0.8500000238418579 CHA 1.0 0.0 0.0 -15.0} {A A 0.8500000238418579 CHA 1.0 0.0 0.0 -14.0} {A A 0.8500000238418579 CHA 1.0 0.0 0.0 -13.0} {A A 0.8500000238418579 CHA 1.0 0.0 0.0 -12.0} {A A 0.8500000238418579 CHA 1.0 0.0 0.0 -11.0} {A A 0.8500000238418579 CHA 1.0 0.0 0.0 -10.0}
Info) Bond count: 20
Info) Atoms: 22
Info) Bonds: 20
Info) Residues: 2
Info) Waters: 0
Info) Segments: 1
Info) Fragments: 2 Protein: 0 Nucleic: 0
psfplugin) WARNING: PSF file is incomplete, no angles, dihedrals,
psfplugin) impropers, or cross-terms will be written.
Info) Opened coordinate file twochains.psf for writing.
Info) Finished with coordinate file twochains.psf.
1
anna,
you need version 1.1 of the topotools plugin, which will be
shipped with VMD 1.9. you either need to install a vmd 1.9
alpha test version or download the updated plugin from
http://sites.google.com/site/akohlmey/software/topotools
Dear Dr Kohlmeyer,
I could not find VMD 1.9 alpha test version that would be available for download and when I download the updated plugin and unzip it into the correct folder, nothing happens...
Yours Sincerely
Anna
Dear Dr Kohlmeyer,
it works for me, so there must be some detail that went wrong.
instructions to get vmd alpha builds are here:
http://www.ks.uiuc.edu/Research/vmd/alpha/
a.
