[lammps-users] Shake Atoms Missing
After running the attached input I got the error that
“ERROR on proc 0: Shake atoms 1 2 3 missing on proc 0 at step 11”
It’s a simulation of water between two slabs.
The lammps help page section on this error says that an atom has probably moved to far.
How can I resolve this?
very respectfully,
in.nick_tip4p_fix_wall (817 Bytes)
data.water_lammps_tip4p_longrange (462 Bytes)
You need to figure out why atoms have moved so far so fast.
You might need to check for reneighboring more often or
reduce your timestep, or you model may just be bad.
