Dear Lammps Users,
I am using the 2020 version of lammps. I am modelling the polyethylene for shock loading using wall/piston comman on the z lower dimension. I am facing some problem while applying the shock load on the simulation cell.
- During the simulation, temperature of the simulation cell overshoot rapidly to a large value and the simulation box dimension increases continuously.
- I am applying the rigid piston on the lower edge of the z dimension and the upper edge of the z dimension getting increased
INPUT SCRIPT
variable fname index data.pe
variable simname index polyethyene
##########Initializing simulation#################
atom_style atomic
atom_modify map array
##Defining Atom Coordinates#####
log log.${simname}.txt
read_data data.pe
Defining potential####################
pair_style airebo 3.0
pair_coeff * * CH.airebo H C
neighbor 2 bin
neigh_modify every 2 delay 0 check no
