I have a couple of questions about running lammps with mpi. I run a
16 processor test job and receive the output as
orthogonal box = (-30 -30 -10) to (30 30 2015)
1 by 1 by 16 processor grid
26048 atoms
Loop time of 242.377 on 16 procs for 5000 steps with 26048 atoms
Pair time (\) = 205\.759 \(84\.8923\)
Neigh time \() = 0.076967 (0.0317551)
Comm time (\) = 4\.6173 \(1\.90501\)
Outpt time \() = 0.0226319 (0.00933751)
Other time (%) = 31.9006 (13.1616)
I have a couple of questions based on this output:
1. I have also read a few log files from lammps examples. I noticed that
most of the log file indicate either 2 by 2 by 1 processor grid or 2 by 2
by 1 processor grid. I assume my simulation box is z direction, therefore,
I have 1 by 1 by 16.
2. The Comm time (\) = 4\.6173 \(1\.90501\) less than 2. Is that too good to
be true?
3. I used the output option
fix OUTPUT_1 all ave/time 1 50 50 c_TW1 c_TR1 &
I am wondering this command will slow down the calculation, since it has
to calculate the temperature every step then average.
4. Is there any optimization available to improve the speed?
I have attached a copy of the input files which can be run as
mpirun -np 16 lmp_xx -var data.cnt < in.nvt
I have a couple of questions about running lammps with mpi\. I run a
26048 atoms
The log file tells you this, so not sure what your question is.
be true?
Apparently not.
Why don't you try turning it off and see if the simulation time changes?
Try running on 1 proc, then 2, 4, etc for a couple 100 timesteps.
That will tell you if you are getting good speed-up. If all the
time is in pair, then you are doing about the best you can.
