hi,
I have input file the attached. When I ran it by the old version lammps(9 jan 2009) I didn’t have any problem. But When I run it by the new version lammps(7 july 2009) I have the problem related with temperature.Lammps are giving high temp values.
RESULT FİLE:
Step Temp TotEng Volume E_pair Press PotEng
0 2 2.9855366 204800 -0.013730964 0.039269945 -0.013730964
100 5.0094121 7.5122836 1423987.8 0 0.014405701 0
200 4.3373495 6.5034545 528130.11 -0.00098138771 0.033611001 -0.00098138771
300 0.95871467 1.249499 107064.88 -0.18822187 0.022222936 -0.18822187
400 2.865612 4.2267416 228437.51 -0.070626886 0.049042118 -0.070626886
500 1.9737571 2.9087317 313690.21 -0.051181047 0.029152228 -0.051181047
600 1.2723189 1.5345482 106338.58 -0.37346414 0.072004612 -0.37346414
700 2.6228492 3.8190696 236416.78 -0.11424366 0.042254968 -0.11424366
800 1.8465369 2.6154832 150475.85 -0.15364589 0.094529 -0.15364589
900 1.9893488 2.4778008 93582.903 -0.50549386 0.092214671 -0.50549386
1000 2.6466462 3.7368912 144642.57 -0.23210888 0.086398921 -0.23210888
10000 2.4118884 1.0748257 22850.112 -2.5421237 1.3367147 -2.5421237
10100 2.3645398 1.0088394 22846.589 -2.5371044 1.3229699 -2.5371044
10200 2.5105514 1.2287521 22759.938 -2.5361556 1.3475001 -2.5361556
10300 2.3767625 0.99263873 22605.56 -2.5716346 1.341734 -2.5716346
10400 2.3831607 0.95067577 22506.039 -2.6231925 1.3960008 -2.6231925
10500 2.3873058 1.0204717 22626.211 -2.5596128 1.39912 -2.5596128
43700 2.4053498 -4.314718 13308.753 -7.9218619 6.4921539 -7.9218619
43800 2.4137049 -4.3444041 13246.304 -7.9640775 6.4974199 -7.9640775
43900 2.4109036 -4.4780772 13230.539 -8.0935498 6.4738649 -8.0935498
44000 2.4091077 -4.3290677 13267.504 -7.9418469 6.4814716 -7.9418469
44100 2.3857717 -4.350458 13254.15 -7.9282418 6.5870279 -7.9282418
44200 2.3445503 -4.4729779 13207.271 -7.9889448 6.5278628 -7.9889448
44300 2.4039762 -4.4697891 13265.243 -8.0748731 6.4645281 -8.0748731
44400 2.4733085 -4.3860449 13245.074 -8.0951019 6.5524212 -8.0951019
Thanks in advance
in.ellipse.gayberne (575 Bytes)
If this is an ellipsoid model, there may have been changes to
the way degrees-of-freedom are computed for aspherical
particles. See the compute temp/asphere doc page. If your
run is doing the same dynamics but only differs in the output
Temp, then this is almost certainly the issue.
2009/7/21 ahmet yıldırım <[email protected]...>:
I arranged according to the new lammps version.The problem related with temp solved but Etot,E-pair …etc values is different according to old lammps version. The arranged file is attach
21 Temmuz 2009 17:07 tarihinde Steve Plimpton <[email protected]> yazdı:
2in.ellipse.gayberne (712 Bytes)
If you can provide an input script/ data file for
a small problem and 2
log files (one for old LAMMPS, one for new) that
gives different energy on timestep 0, then I'll look
at it.
old version
0 1 1.4859028 204800 -0.013730964 0.019274828 -0.013730964
100 3.0807167 4.6199469 541073.83 0 0.023315737 0
200 2.0798482 3.0660436 127462.73 -0.052966936 0.074482962 -0.052966936
300 0.46079227 0.40648718 71975.278 -0.28453247 0.060444971 -0.28453247
400 1.3700331 1.9394011 144399.33 -0.11514683 0.031681508 -0.11514683
500 0.78535025 0.98913604 112155.39 -0.18860173 0.068346453 -0.18860173
600 0.80608822 0.58781284 70353.456 -0.62102429 0.052799206 -0.62102429
700 1.0617594 0.96844534 72138.873 -0.62380499 0.05899637 -0.62380499
800 0.85987925 0.41457271 61728.978 -0.87493127 0.072955963 -0.87493127
900 1.012192 0.38903675 52951.324 -1.1288806 0.086961043 -1.1288806
1000 0.95008801 0.07109522 47037.348 -1.3536889 0.11166924 -1.3536889
1100 0.96924021 -0.15781544 42311.874 -1.6113208 0.099457283 -1.6113208
1200 0.9775549 -0.37885228 38908.928 -1.8448266 0.12416179 -1.8448266
1300 0.9745631 -0.6545696 35638.556 -2.1160573 0.12325812 -2.1160573
1400 0.95871689 -0.89453512 33364.696 -2.3322594 0.16460932 -2.3322594
1500 0.99534827 -1.0855563 31439.353 -2.5782142 0.18436441 -2.5782142
1600 0.96319285 -1.4231766 29553.195 -2.8676132 0.19363633 -2.8676132
new version
100 3.0808833 4.6201967 541092.43 0 0.023316196 0
200 2.079792 3.0659668 127480.3 -0.052959538 0.074463392 -0.052959538
300 0.46081334 0.4065155 71975.911 -0.28453575 0.060440462 -0.28453575
400 1.3701043 1.939524 144409.26 -0.11513062 0.031682495 -0.11513062
500 0.78538686 0.98925088 112161.79 -0.18854179 0.068362456 -0.18854179
600 0.80609028 0.58778908 70351.889 -0.62105113 0.052811047 -0.62105113
700 1.0618662 0.96848238 72142.973 -0.62392813 0.058942985 -0.62392813
800 0.85991908 0.4147143 61725.603 -0.87484942 0.073161341 -0.87484942
900 1.0118918 0.38939268 52964.013 -1.1280745 0.087231374 -1.1280745
1000 0.95015367 0.071761224 47045.757 -1.3531213 0.11160004 -1.3531213
1100 0.9688753 -0.15599497 42332.246 -1.6089531 0.1003922 -1.6089531
1200 0.97694068 -0.37801017 39021.424 -1.8430634 0.11629529 -1.8430634
1300 0.97327713 -0.6550616 35609.433 -2.1146209 0.12872371 -2.1146209
1400 0.94884961 -0.90212825 33455.116 -2.3250552 0.16024672 -2.3250552
1500 0.99106081 -1.0945815 31563.655 -2.5808098 0.16278841 -2.5808098
1600 0.95833094 -1.4220477 29673.985 -2.8591932 0.1639731 -2.8591932
22 Temmuz 2009 17:12 tarihinde Steve Plimpton <sjplimp@…29…> yazdı:
I provided an input script/ data file for
gives different energy and velocity on timestep 0. The differences is rising when run step is enhanced.
The files is attach
22 Temmuz 2009 17:27 tarihinde ahmet yıldırım <ahmedo047@…24…> yazdı:
new_in.ellipse.gayberne (710 Bytes)
new_log.lammps (4.17 KB)
old_in.ellipse.gayberne (573 Bytes)
old_log.lammps (3.94 KB)
The 2 runs appear to give identical answers for everything
on timestep 0, then slowly drift apart. I'm guessing that
for long times, they give identical results in a statistical (time-averaged)
sense? If so, I don't consider this a bug. There are a variety
of reasons why small changes to the code can cause round-off and
other changes that induce this. If you're worried about it, I suggest
you diff source files for the relevant features (pair potential, aspherical
integrators and temperature, and fixes, etc) between the old
and new codes and look for differences. I don't remember at this
point all the changes that were made.
2009/7/22 ahmet yıldırım <[email protected]...>:
