[lammps-users] subtracting coulombic interactions
In a solution, I would like to subtract the coulombic interaction within water molecules, while I keep the coulombic interactions between different molecules. The potential for all the O-H O-O H-H is a LJ+long range coulomb and the internal is an harmoni OH and angular HOH. In other words, I want to remove the LJ within the water molecules. is it possible?
your are contradicting yourself.
what do you want to remove: coulomb or LJ?
If you want to remove both (i.e. all pair interactions
within the water molecules) then the neigh_modify
exclude molecule command should do it.
