2009/3/4 shihai feng <sfeng@…795…>
HeHe. Did that too. The same.
pair_coeff 1 1 tablepot soft
ERROR: Invalid pair table cutoff
Okay. There are a couple of problems here:
(1) You used 0 as the transition value. LAMMPS doesn’t like that.
(2) LAMMPS doesn’t distinguish between a problem with the overall cutoff and a row cutoff. Perhaps the code for this error can be changed to return “Invalid pair table row cutoff” to make the distinction easier to catch.
–AEI
AEI,
Thank you very much.
I am not sure I understand what you mean “You used 0 as the transition value”? Did you mean I used "1 0 11454.9727 -2416.39795’, if that is what you meant ( which I though it is), I changed it to “1 0.0 11454.9727 -2416.39795” but still doesn’t work.
pair_coeff 1 1 tablepot soft 14.0
with potential file
[sfeng@…1180… argo1]$ cat tablepot
#blobs
soft
N 11
2 6. 1541.74219 -888.012207
3 7. 781.095703 -633.28125
4 8. 275.179688 -378.550293
5 9. 23.9941406 -123.819336
6 10. -2.38764048 5.09873295
7 11. -0.398213595 0.586846709
8 12. -0.113104202 0.122381844
9 13. -0.043384701 0.0369814932
10 14. -0.0200307649 0.0140784299
11 15. -0.010482925 0.00626723375
Shihai
