Hi Lammps,
I am simulating a flow with time dependent body force. I could manage to create sinusoidal body force using
the variable and jump commands. However the temperature of the system is gradually decreasing with time.
Here is part of my input script where I do this.
variable pi equal 3.14159265
variable tp equal 1000
variable alpha equal 0.005
variable con equal 2*{pi}/{tp}
variable neq equal 200000
variable navg equal 400000
reset_timestep 0
label loop
variable t loop {neq}
variable f equal 0.05+{alpha}sin(${con}$t)
fix 4 flow addforce $f 0.0 0.0
run 1
unfix 4
next t
jump equil.in loop
Srikanth
