Hello users,
I am working on CNT - Silicon interface using Tersoff potential for all atomic interactions. In the following code, Cold and hot are two regions at the center of CNT and silicon. I am using Periodic boundary conditions in X direction which is the axis of CNT. The coordinates of all atoms are read from an input file. I had defined the masses as 12 & 28 for both of them. The NVT part of the code was working well the average temp of 300K at the end of it. But when i move the system to NVE and start adding & removing heat, the average temperature of the system is increasing upto 600K. I don’t know why this is happening even though the total energy is constant.
1-d Structure
boundary p s s
atom_style atomic
pair_style tersoff
read_data coordinates.txt
pair_coeff * * SiC.tersoff C Si
velocity all create 300 873586443 dist gaussian
fix 1 all nvt 300.0 300.0 0.5 drag 0.4
#output of varaibles
timestep 0.001
thermo 1000
run 40000
unfix 1
fix 4 all nve
fix 7 cold heat 1 0.5
fix 8 hot heat 1 -0.5
timestep 0.0005
run 500000
Ajit
