Hi there,
I found an interesting thing with the thermo output of pressure with custom style.
When I use the following command to output thermo properties:
thermo_style custom step temp pe ke enthalpy press pxy pxz pyz
The result for “pressure” is actual zero, instead of (pxx+pyy+pzz)/3. And if I use:
thermo_style custom step temp pe ke enthalpy pxy pxz pyz press
all the pressure components are zero; but if I use just:
there seems to be no problem.
Attached are the script to run the job and the configuration file.
Thanks.
data.pos (259 KB)
in.LJ2D (1.48 KB)
