[lammps-users] thermostating for low-T NPT sims in LAMMPS
Hi, all. I have a question about the relative merits of different thermostatting protocols (available within LAMMPS) at low T. I will be running NPT-ensemble simulations, so obviously the Nose-Hoover thermostat/barostat combination seems a natural choice. One problem that comes to mind (and is mentioned in the docs), however, is that the N-H thermostat can produce “ringing” in sims. of crystals (and I am simulating crystals, so this is a worry). One way around this is to use a thermostat ‘period’ tau_{therm} which is well below (and not a divisor of) the barostat period tau_{bar} (i. e. the time over which P is brought to P_target).
I guess another way is to use the ‘drag-damping’ functionality available in fix_npt. The webpage says “A value of 0.0 (no drag) leaves the Nose/Hoover formalism unchanged. A non-zero value adds a drag term; the larger the value specified, the greater the damping effect. Performing a short run and monitoring the pressure and temperature is the best way to determine if the drag term is working. Typically a value between 0.2 to 2.0 is sufficient to damp oscillations after a few periods.”
However, the drag may itself affect the thermodynamics, in ways I don’t have a good feel for. My question, then, is:
Is anyone here expert in sims. in this regime and familiar with the ‘pitfalls’? Or at least, could someone point me towards article(s) discussing them? Both NPT-at-low-T and how adding drag affects things? This is a bit above the level of say, the Frenkel & Smit textbook.
For example, I’ve heard the ringing is worst at ‘low’ T, but what is ‘low’? 10% of the melting temperature? Specific to LAMMPS, is it better (in terms of physical realism) to increase or decrease the drag as T increases, or leave it constant?
I guess a one-sentence summary is (ideally) I’m looking for an advanced thermostatting reference that covers the ‘NPT-at-low-T’ options within LAMMPS, and any help would be appreciated.
Rob
I don't know of any reason low T is any worse than hi T. What always
causes problems for NH (thermo or barostat) is if you pick a target
far away from where you currently are and try to change to it
instantaneously. But if you are well equilibrated and then pick T,P
targets near those equil values, you shouldn't have any big
oscillations.
