[lammps-users] three questions of wall_lj126
Dear ALL,
I have three questions of wall_lj126.
1.the main idea of adding the z-cylinder boundary to the fix_wall_lj126 command
  1. the use of the “fwall” and the “wall”.
  2. the use of “wall_flag”. Is it just for MPI flag?
Hope for any suggestions!!!
I want to add the z-cylinder boundary to the fix_wall_lj126 command. After perused the source code of fix_wall_lj126.cpp and fix_wall_lj126.h, I found that the key point is distributing the force f into fx and fy directions and then add them of the force which interact on the particle as the sketch shown below.
I add
int wallstyle; //to distinguish cylinder type from previous type.
double cylinder_X,cylinder_Y,cylradius; //to record the x and y axis and radius of the cylinder.
in fix_wall_lj126.h.
Am I right?
I felt that the force computation is located at the FixWallLJ126::post_force(int vflag). The exact part
for (int i = 0; i < nlocal; i++)
if (mask[i] & groupbit) .
There are two punch-drunk parameters in this part. There are the “fwall” and the “wall”. Both of them have 4 components. Is it the first component is the overall value and the other there for x y z directions? Whether the “fwall” means the force from the wall and the “wall” means the potential? Why the fwall can be directly added to wall?
The original source is
if (mask[i] & groupbit) {
if (side == -1) delta = x[i][dim] - coord;
else delta = coord - x[i][dim];
if (delta <= 0.0) continue;
if (delta > cutoff) continue;
rinv = 1.0/delta;
r2inv = rinv*rinv;
r6inv = r2invr2invr2inv;
fwall = r6inv*(coeff1*r6inv - coeff2) * side;
f[i][dim] -= fwall;
wall[0] += r6inv*(coeff3*r6inv - coeff4) - offset;
wall[dim+1] += fwall;
So I modifid that
if(wallstyle==1)
double del_x,del_y,del_xy;
del_x=del_y=del_xy=0;
double fwall_x,fwall_y;
fwall_x=fwall_y=0;
del_x=(x[i][0]-cylinder_X);
del_y=(x[i][1]-cylinder_Y);
del_xy=sqrt(del_xdel_x+del_ydel_y);
delta=cylradius-del_xy;
rinv = 1.0/delta;
r2inv = rinv*rinv;
fwall = r6inv*(coeff1*r6inv - coeff2);
fwall_x= fwall*del_x/del_xy;
fwall_y = fwall*del_y/del_xy;
f[i][0] -= fwall_x;
f[i][1] -= fwall_y;
wall[1] += fwall_x;
wall[2] += fwall_y;
The mail list can't help you write code. You'll just have
to debug and try things out yourself.
