Dear Lammps-users,
Is there anyway to get different views of the model without rotating it manually. I am working with carbon nanotubes, when I import the result file into VMD, it shows me the model from the cross section view of nanotube. I want to see the top view of the nanotube.
Regards,
Iman.
That seems like a VMD question, not a LAMMPS question.
Can't you just rotate the view with the mouse in VMD?
Try to put the following into a file named .vmdrc in your working
directory:
after idle {
rotate x by 90
menu main on
You will to replace "x" by the desired rotation axis.
Lutz
2009/1/16 Lutz Maibaum <lutz.maibaum@…24…>
