[lammps-users] Trouble compiling LAMMPS with REAX option
I'm trying the new version of LAMMPS with the REAX force field.
Unfortunately, I'm unable to compile it successfully. More
specfically, when I compile the file pair_reax.cpp, it gives me the
below error message:
pair_reax_fortran.h:63: warning: non-local variable '<anonymous
cbkabo_' uses anonymous type
pair_reax_fortran.h:67: warning: non-local variable '<anonymous
cbkbo_' uses anonymous type
pair_reax_fortran.h:72: warning: non-local variable '<anonymous
cbkc_' uses anonymous type
pair_reax_fortran.h:76: warning: non-local variable '<anonymous
cbkch_' uses anonymous type
pair_reax_fortran.h:82: warning: non-local variable '<anonymous
cbkchb_' uses anonymous type
pair_reax_fortran.h:86: warning: non-local variable '<anonymous
cbkd_' uses anonymous type
pair_reax_fortran.h:93: warning: non-local variable '<anonymous
cbkvirial_' uses anonymous type
pair_reax_fortran.h:98: warning: non-local variable '<anonymous
cbkia_' uses anonymous type
pair_reax_fortran.h:103: warning: non-local variable '<anonymous
cbklonpar_' uses anonymous type
pair_reax_fortran.h:108: warning: non-local variable '<anonymous
cbknubon2_' uses anonymous type
pair_reax_fortran.h:115: warning: non-local variable '<anonymous
cbkpairs_' uses anonymous type
pair_reax_fortran.h:119: warning: non-local variable '<anonymous
cbknvlbo_' uses anonymous type
pair_reax_fortran.h:123: warning: non-local variable '<anonymous
cbknvlown_' uses anonymous type
pair_reax_fortran.h:127: warning: non-local variable '<anonymous
cbkqa_' uses anonymous type
pair_reax_fortran.h:151: warning: non-local variable '<anonymous
cbkenergies_' uses anonymous type
pair_reax_fortran.h:165: warning: non-local variable '<anonymous
rsmall_' uses anonymous type
I will be most grateful if someone can help me out here.
Regards,
Zhun-Yong
these are all warnings, but no errors.
if there is a problem, it has to be elsewhere.
cheers,
