I am a new user of LAMMPS. I would like to compute a two dimensional density profile of liquid water in a 3 dimensional surface. I know there is fix ave/spatial command which can calculate density profile in 1 dimension. However, is there any other command which can calculate a 2D density profile by providing the bin size/number of bins.
there is no 2d fix ave/spatial command yet. Someone
would have to write it. You can always dump info to
a dump file and post-process it, binning it however you
wish.
The atc package is capable of doing the averaging you want, and I have used it to compute the density of water and ions in a nanochannel (or more specifically of the oxygens, but you can figure out the rest). Here is my example code for averaging in only one direction as an example:
fix WHARDY water atc field
fix_modify WHARDY fem create mesh 1 1 40 ATC_BOX p p f
fix_modify WHARDY atom_element_map eulerian \{dumpfreq\}
fix\_modify WHARDY transfer fields none
fix\_modify WHARDY transfer fields add density velocity
\# output
fix\_modify WHARDY transfer output nanochannel\_whardyFE {dumpfreq} text binary
Jon Zimmerman is the author of this part of the atc package and has documentation through the lammps website.
regards,
Jeremy
