I am trying to equilibrate a spherical core (12.27 angstrom in radius) of 441
silver atoms, using EAM potential. The initial temp I have set is 500 K.
I used the following velocity command to nullify the aggregate angular
momentum.
velocity all zero angular
Yet, I found an unbalanced rotational motion in the YZ plane (though not in
the XY or XZ plane)!
Only when I additionally used the following fix command did I get zero angular
momentum in all three planes with just oscillatory motion about respective
mean positions.
fix 2 all momentum 100 angular
Could you please suggest why this fix command is needed in spite of setting
the angular momentum to zero using the velocity command. Is this a
characterictic of the EAM potential or a possible bug?
Again, your help would be highly appreciated.
I am pasting below my piece of code (with the second fix commented).
