Hello all,
I am calculating A * exp(-rij/rho)) - (C/(rij**6) (buck)+ 4 * eps * ( ( sig/rij )**12 - (sig/rij)**6 ) (lj) Vs coulombic (qiqj/rij) interaction energies by hand and would like to compare them to my simulation in lammps. Pair potentials as given below :
pair_style hybrid buck/coul/long 8.0 lj/cut/coul/long 8.0
pair_coeff 1 1 buck/coul/long 717647.4 0.154 121.0676
pair_coeff 2 2 buck/coul/long 271716.3 0.234 696.8883
pair_coeff 1 2 buck/coul/long 391049.1 0.194 290.3317
pair_coeff 1 3 buck/coul/long 28593.02 0.265 148.000
pair_coeff 2 3 buck/coul/long 271716.3 0.234 696.8883
pair_coeff 2 4 buck/coul/long 7088.0 0.2563 51.975
pair_coeff 3 3 lj/cut/coul/long 0.1553 3.166
pair_coeff 1 4 lj/cut/coul/long 0.00144 3.7475
pair_coeff 4 4 lj/cut/coul/long 0.00 0.0
what would be the units of these energies calculated Vs those as printed out by thermo_style multi ? Particlularly ecoul and buckingham(both as compared to say kcal). And how are the conversions done ? Am sorry but I couldnt follow/undrstand the doc respective page.
http://lammps.sandia.gov/doc/units.html
Sincerely,
Ritwik.
Hello all,
you didn't tell what is the units setting that _you_ are using.
everything depends on that. depending on that, input and output
use the same units.
_what_ did you not understand? where is the problem?
cheers,
sorry about that. my units are:
units real
the doc page says
For units lj
mass, sigma, epsilon, and the Boltzmann constant = 1 (what is sigma and epsilon here ?)
energy = epsilon, where E* = E / epsilon
And for units real
energy = Kcal/mole. (does that mean the print from thermo_style multi gives ecoul and other energy terms in kcal/mole ?)
Thus are there any conversion factors needed for the formulae below to get the same units as in lammps. (no we are not comparing the values, but I would like to get the same units used in lammps for my interactions calculations)
A * exp(-rij/rho)) - (C/(rij**6) (buck)+ 4 * eps * ( ( sig/rij )**12 - (sig/rij)**6 ) (lj) and coulombic (qiqj/rij)
thank you,
Ritwik
units realthe doc page says
For units lj
epsilon here ?)
but you are _not_ using lj units (which are reduced units), so this
does not apply.
And for units real
if you set units real, then you have to give input energies in
kcal/mol, distances
in angstrom and so on, and you get output energies in kcal/mol, angstrom and
so on.
calculations)
well, you have to look or figure out in which units A, C and so
on are and then you should get the same in your test calculations.
coulomb is a special case, since the typical formula usually skip
the conversion factor for elementary charges^2/angstrom to energy.
but that is less of a problem for lammps but rather for your
manual calcuation.
cheers,
