I am try to use the variable command for text in the following way:
variable JOBNAME equal “job-xyz”
dump 1 all atom 100 ${JOBNAME}.lammpstrj
which gives the error message: ERROR: Invalid thermo keyword in variable formula
So it is not interpreting the ${JOBNAME} as text. How to fix this?
Fred Phelan
variable JOBNAME equal "job-xyz"
formula
there is no reason to define an equal-style variable for this.
you can use an index style variable, for example.
that would have the added benefit, that you can override it
from the command line with: -var JOBNAME new-job
i often use this in the form: -var JOBNAME myjob-${PBS_JOBID}
to name output files uniquely by the unique job identifier
from the batch system.
cheers,
More strongly, it's an error to do so. An equal-style
variable is an equation. LAMMPS can't evalulate
an equation with arbitrary strings in it.
As Axel says, the other styles of variables are what you
want for this case.
