Dear Lammps Community,
I have a heterogenous FENE polymer chain model immersed in a heterogeneous WCA (LJ) fluid (4 different atom types). The LJ particle sigmas range from 0.5 to 5.0, so I want to use multi style in neighbor and multi keyword in comm_modify to increase performance.
Based on what I realized from the doc about the multi option, this algorithm groups particles based on their sizes (not based on the original atoms types defined in Lammps) into a series of collections or types; for instance, if a chain monomer (atom type 1) and a fluid particle (atom type 3) have the same size, they are assigned to the same collection or type in the multi algorithm*.* Is my understanding correct? I also want to use the multi and cutoff/multi keywords in comm_modify for communication. The doc recommends that a ghost cutoff > neighbor cutoff is used in systems similar to mine (that satisfies the first two example given in the doc after reduce/cutoff explanation), but I do not know how to properly set ghost cutoff.
Given my understanding is correct, Is setting “ghost cutoff=1.5*the largest pair cutoff diameter in a collection” good?
variable cutoff11 equal 11.122462 # small monomers in the FENE chain
variable cutoff22 equal 51.122462 # large monomers in the FENE chain
variable cutoff33 equal 11.122462 # # small beads in the WCA fluid
variable cutoff44 equal 0.51.122462 # large beads in the WCA fluid
neighbor 0.3 multi
neigh_modify delay 0 every 1 check yes collection/type 3 1 2 3*
variable gfactor equal 0.5 # This is a factor for increasing ghost cutoff
variable gskin1 equal {cutoff11}+(1+{gfactor})
variable gskin2 equal {cutoff22}+(1+{gfactor})
variable gskin3 equal {cutoff33}+(1+{gfactor}) # since cutoff33 is always larger than cutoff44
comm_modify mode multi cutoff/multi 1 {gskin1} cutoff/multi 2 {gskin2} cutoff/multi 3 ${gskin3}
Thank you in advance for your help.
Bests,
Amir
