Dear LAMMPS users,
A segment in my input file:
variable l loop 1000
variable r equal mult(2000,$l)
read_restart restart.$r
When the variable l=500 and r=1000000, I found an error:
read_restart restart.1e+6
Apparently, my file is restart.1000000. So it stops and can't go on.
Could someone tell me how to get rid of it?
Any suggestion is appreciated!
Lines like this in variable.cpp
sprintf(result,"%g",answer);
are what write the 1.0e-6 into the string that becomes
the filename. So you could try playing with the format
of those.
Or assuming you created the restart files from a previous
LAMMPS run, you could rename them to smaller digits.
Then this script could generate smaller numbers and have
no problem.
Thank you for your explanations.
Yes, I created the restart file via the last version of LAMMPS, and now
I know the reason that I got "1.0e+6" string. I have changed the file name
to get small digits.
