I’d like to flip the coordinate of atom inside simulation box when atom’s cooridnate is out of range of simulation box before update list process.
Is there a command to perform such a job it in LAMMPS? -
Is there variable for image flag of a certain atom?
I can’t find it and if I’d like to see and change image flags of a certain atom, what should I do for it? -
To calculate deviation distance of every atom for the skin depth of neighbor list, original position per every atom should be required, as you now.
I think there is a variables for coordinate and image flag of original poisition per every atom, whether it is predefined variable or inner-use only
variable.
If I can see and change such variables, what should I do for it?
Luke
