Here is the output of ./lmp -h:
Large-scale Atomic/Molecular Massively Parallel Simulator - 29 Oct 2020
Git info (stable / stable_29Oct2020)
Usage example: ./lmp -var t 300 -echo screen -in in.alloy
List of command line options supported by this LAMMPS executable:
-echo none/screen/log/both : echoing of input script (-e)
-help : print this help message (-h)
-in filename : read input from file, not stdin (-i)
-kokkos on/off … : turn KOKKOS mode on or off (-k)
-log none/filename : where to send log output (-l)
-mpicolor color : which exe in a multi-exe mpirun cmd (-m)
-nocite : disable writing log.cite file (-nc)
-package style … : invoke package command (-pk)
-partition size1 size2 … : assign partition sizes (-p)
-plog basename : basename for partition logs (-pl)
-pscreen basename : basename for partition screens (-ps)
-restart2data rfile dfile … : convert restart to data file (-r2data)
-restart2dump rfile dgroup dstyle dfile …
: convert restart to dump file (-r2dump)
-reorder topology-specs : processor reordering (-r)
-screen none/filename : where to send screen output (-sc)
-suffix gpu/intel/opt/omp : style suffix to apply (-sf)
-var varname value : set index style variable (-v)
OS: Linux 3.10.0-1160.11.1.el7.x86_64 on x86_64
Compiler: GNU C++ 4.8.5 20150623 (Red Hat 4.8.5-44) with OpenMP 3.1
C++ standard: C++11
MPI v3.1: Intel(R) MPI Library 2018 Update 3 for Linux* OS
Active compile time flags:
-DLAMMPS_GZIP
-DLAMMPS_PNG
-DLAMMPS_JPEG
-DLAMMPS_SMALLBIG
sizeof(smallint): 32-bit
sizeof(imageint): 32-bit
sizeof(tagint): 32-bit
sizeof(bigint): 64-bit
Installed packages:
ASPHERE COLLOID DIPOLE GRANULAR KSPACE MANYBODY MC MOLECULE
Chandana
