hello,
I am trying to relax a small polymer network with about thousands of atoms in LAMMPS to get a correct density. I minimized the energy first and run MD for 20000 steps under NPT ensemble. The problem is that the volume of the box keeps increasing to several times of the original one while temp and pressure fluctuate in a normal range. I wonder if this is normal or i got something wrong. Here is the input file. Thanks!
units real
atom_style molecular
pair_style lj/cut 10.0
read_data custom.dat
pair_modify mix geometric
pair_coeff 1 1 0.0038 3.195
pair_coeff 2 2 0.02378 3.8983
pair_coeff 3 3 0.02378 3.8983
pair_coeff 4 4 0.01935 3.6621
pair_coeff 5 5 0.02393 3.4046
pair_coeff 6 6 0.02393 3.4046
pair_coeff 7 7 0.0860 4.03
thermo 100
minimize 1.0e-4 1.0e-4 1000 10000
dump 1 all atom 100 custom.dump
fix 2 all npt 300.0 300.0 100 xyz 1.0 1.0 1000.0 drag 2.0
run 20000
