I’m trying to set a wall to simulate an impact.
I’m using the wall/lj93 configuration.
fix wallhi all wall/lj93 xlo __*-1.0*__ 1.0 1.0 2.5 units box
I’m a bit confused with the wall position coordinate (-1). is it the actual coordinate of the distance fromthe box edge?
ps: when I use the edge option the simulation fails right away;
With less typos
I’m a bit confused with the wall position coordinate (-1). is it the actual coordinate or the distance from the box edge?
