Hi all,
I am still having trouble getting this simulation to run. I am getting
an error that my pair coefficient arguments are invalid. I have
specified the cutoff and made sure it is the same.
Can anyone see anything wrong with my input script??? Thanks...This is
shown below:
# Nanofluid simulation input script
neighbor 0.3 bin
neigh_modify delay 5
atom_style full
kspace_style pppm/tip4p 1.0e-4
read_data dataNULLcharge.nanofluid
#Pair_style hybrid definition
pair_style hybrid lj/cut/coul/long/tip4p 2 1 1 1 0.1250 2.5 eam lj/cut 2.5
#Definition of pair coefficients
#Water
pair_coeff 1*2 1*2 lj/cut/coul/long/tip4p 0.0 0.0 2.5 #pair
coefficients for tip4p between OH (LJ parameters set to zero)
pair_coeff 1 1 lj/cut/coul/long/tip4p 0.0 0.0 2.5 #pair
coefficients for tip4p between HH (LJ parameters set to zero)
pair_coeff 2 2 lj/cut/coul/long/tip4p 0.16275 3.16435 2.5 #pair
coefficients for tip4p between OO
bond_style harmonic
bond_coeff 1 450.000000 1.000000 #still not sure about these. How
did you work out that K is 450.000000!
angle_style harmonic
angle_coeff 1 55.000000 104.52 #still not sure about these. How did
you work out that K is 55.000000!
#Gold
pair_coeff 3 3 eam Au_u3.eam #pair coefficients for gold - where did
this come from???
#Water and gold together
pair_coeff 1*2 3 lj/cut 2.5 #pair coefficients for interaction
between water and gold is this correctly defined???
group hydrogen type 1
group oxygen type 2
group gold type 3
group all union hydrogen oxygen gold
fix 1 all nve
fix 2 all temp/rescale 100 0.45 0.45 0.02 1.0
fix 3 all enforce2d
thermo 50
run 1000
Kind regards,
Folayo Osekita
MEng Student, Queen Mary, University of London
