Hello
Dear Ahmed,
I intend to simulate pure water. in order to do this, I have written a script as below:
units real
neigh_modify delay 2 every 1
atom_style full
bond_style harmonic
angle_style charmm
pair_style lj/charmm/coul/long 8 10
kspace_style pppm 1e-4
read_data solvate.data
pair_coeff 1 1 0.0460 0.4000 .0460 0.4000 # H
pair_coeff 2 2 0.1521 3.1507 0.1521 3.1507 # O
pair_coeff 1 2 0.0836 1.7753 0.0836 1.7753 # H-O
special_bonds charmm
minimize 1e-9 1e-11 100000 1000000
fix 1 all nve
fix 2 all shake 1e-6 500 0 m 1.0 a 1
fix 3 all langevin 300.0 300.0 800 123456
velocity all create 300.0 12345678 dist uniform
thermo 10
thermo_style multi
timestep 0.5
run 400000
unfix 1
unfix 3
fix 4 all npt 300.0 300.0 2 xyz 1.0 1.0 60 drag .05
run 4000000
I have some problem on set parameters : Tdamp , Pdamp and drag factor. have there any rule for set this parameter?
I try to set this parameter till temp =300 and press=1 in real unit. temp can be balanced but press no. would you help me.
Thanks a lot
Yasti
