hi all
I want to simulate TIP4P water. When I am checking harmonic angle and bond style, it is given that I have to give value of prefactor K (energy/radian^2) in data file. what is the value of this K for TIP4P water?
hi all
tip4p is a rigid water potential, i.e. it requires the use of fix shake.
thus the force constants are irrelevant, they just need to be present.
i would set them to some rather large numbers, e.g. about 1000x
larger than typical values, so that you can use minimize as well
without distorting the water structure significantly.
Also, you can see the howto section of the LAMMPS manual,
which has a section on TIP4P settings.
thank you…
