Dear Friends,
I want to simulate water moleculs in NPT ensemble. At first I minimized the system using ‘fix minimize’ and then I use ‘fix npt’ :
fix 3 all npt 2910.0 2910.0 0.001 xyz 2.9752 2.9752 0.1
(2910 is the reduced temperature equal to 25C and 2.9752 is the reduced pressure equal to 1 atm)
but I recieve the following error and warning:
WARNING: One or more atoms are time integrated more than once
Setting up run …
Memory usage per processor = 99.7679 Mbytes
Step Temp E_pair E_mol TotEng Press Volume
242 1800.2055 -4.7878546e+12 0.017421397 -4.7878546e+12 -1.9544884e+10 4913
ERROR: Out of range atoms - cannot compute PPPM
Is it possible help me?
Best regards
Nahid
