[lammps-users] xmovie does not like new dump custom output
I found that xmovie does not like the new dump custom output and the problem is that the line
ITEM: ATOMS
cannot contain any additional non-space characters after the word ATOMS. The new dump custom adds the title of the columns after ATOMS. I was able to edit the file "dump_custom.cpp" and change the line
fprintf(fp,"ITEM: ATOMS %s\n", columns);
to the following
fprintf(fp,"ITEM: ATOMS\n");
and then recompile to allow xmovie to work as usual.
ITEM: ATOMS
to the following
chuck,
it would be better to keep the dump format as is and
teach xmovie to read the new format. that change was
made for a very good reason. if you need help with
that, i can take a look.
cheers,
