Lammps version
Dear LAMMPS users,
I am trying to run an input script which has been written in 2013 but when I run the code, I receive the following error:
ERROR: Illegal lattice command (…/lattice.cpp:55)
Last command: lattice none
I have actually installed a 2017 version of LAMMPS and I was wondering because of using a newer version of LAMMPS, I receive this error or no.
I’m pretty sure that the code is correct.
Many thanks for your help!
Dear LAMMPS users,
ERROR: Illegal lattice command (../lattice.cpp:55)
I'm pretty sure that the code is correct.
​...and *I* am pretty sure, that your input is *not* correct, or else
LAMMPS would not throw the error message.
compare the command with the documentation *MATCHING* the version of LAMMPS
*THAT YOU ARE USING*, and you'll find out.
LAMMPS is continually updated and improved and that may also mean, that the
syntax of commands may change in a non-backward compatible way. in fact,
this information is documented here: http://lammps.sandia.gov/bug.html
the fact that an input "was working" for an older version of LAMMPS is no
proof in any way, that it is correct to be used with a newer version of
LAMMPS.
you need to read the documentation and double check. always!
Dear Axel: Thank you for your reply. Best,
Dear LAMMPS users,
​…and I am pretty sure, that your input is not correct, or else LAMMPS would not throw the error message.
compare the command with the documentation MATCHING the version of LAMMPS THAT YOU ARE USING, and you’ll find out.
LAMMPS is continually updated and improved and that may also mean, that the syntax of commands may change in a non-backward compatible way. in fact, this information is documented here: http://lammps.sandia.gov/bug.html
the fact that an input “was working” for an older version of LAMMPS is no proof in any way, that it is correct to be used with a newer version of LAMMPS.
