LAMMPS Windows MPI runs
I want to run an example on windows in parallel, after installation MPICH2 and Putting smpd.exe & mpiexec.exe in the directory according to manual,
a. when i write : mpiexec -np 4 -localonly lmp_win_mpi -in in.model it does not work.(Just show “Unknown option: -localonly” and does not issue any error);
b. when i write : mpiexec lmp_win_mpi -in in.model it does not work, and show a system error: the mpich2mpi.dll is missing;
Please help me.
Thank you
This sounds like an MPI problem, not a LAMMPS problem.
Can you run any MPI program in parallel, e.g. the test
problems that come with MPICH ?
not work.(Just show "Unknown option: -localonly" and does not issue any
error);
it doesn't work because it is not correct. please refer to the MPICH
documentation. you can use *either* -np *or* -localonly
this should not happen with the windows executables from here:
http://git.icms.temple.edu/rpm/windows.html
which do *not* require copying the lammps or MPICH executables anywhere.
