Hello
I have one query that if i compile Lammps with python ,then can I get an user interface as the picture shown in the Lammps manual,where I am using lammps in a dual core processor not a parallel computing system?In such case what instruction I have to follow ,as I am a new Lammps user so if you help me by giving the details command for ubuntu and tell me what the actual step I have to follow,I really would be thankful to you.please help.If I get interface then would it be necessary to install pizza.py separately ? Waiting for your response .
Hello
Lammps with python?
LAMMPS is written in C++. Pizza.py (and moltemplate) are written in
python (among others..)
,then can I get an
Interface ?
Really ?
I am using
Compile LAMMPS by entering the "src/" subdirectory, copying the
makefile to the "MAKE/" subdirectory, and typing
make yes-shock #<--I'm assuming you need this package
make ubuntu
After it is compiled, (and after you have copied the lmp_ubuntu file
to somewhere in your PATH), you can run lammps in parallel using both
cores using a command like:
,then can I get an
Interface ?
Really ?
there is no real GUI, but using the python interface
(and TkInter) one can do custom demos with a GUI
using tools like VMD or atomeye or pizza.py as a backend.
Hello
you are making your life needlessly miserable by trying to use
the python interface. start with a regular serial lammps executable.
using the python interface requires intimate knowledge of how
lammps works without the python wrapper.
dual core is still parallel. but for learning purposes you can
also compile and use the serial version.
just read the documentation. it explains how to compile lammps in
great detail. if you don't understand what is written there, you should
contact/find somebody local that *does* understand this and learn
from this person how to compile software. this is not a lammps
specific thing and will be extremely helpful to you in the future.
there is no GUI for LAMMPS. pizza.py is independent. you don't
have to use it.
