Hi my name is bryan and I have a question regarding lammps2001.
In the program, when you run a restart of an NPT run with another NPT run, it appears to not be a perfect restart. What I have noticed with my runs is that when using LJ configuration, the restart pressure does not match the final pressure of the previous run. Whats the reason for this? Shouldn’t they match?
One other thing on the matter is when using real conditions, the restart of an NPT with an NPT also has discontinuous values for Ecoul, Elong, Ebond, Volume, Evdwl. Why does this happen also? Shouldn’t it be a perfect restart? When you run NVT runs the restart values are perfect but when an NPT continues an NPT those 5 values do not match the final values of the the previous. IE step 500 on run 1 has certain values, but run 2 at step 500 does not have the same value.
Was just wondering the reason and how significant this problem is to the overall data since all the other measured values match up except for those 5?
