Dear lammps users,
I’m trying to use langevin thermostats as hot/cold reservoir to obtain thermal conducivity. I can obtain a value of thermal conductivity from the script. However, I find that the temperature value is not the one I set. (I set 330K for the hot end, but it fluctuates around 315K instead. Similarly for the cold end). I wonder if I can fix it at 330K by changing setting of langevin. My script is in the attachment.
Any suggestions will be appreciated
variable T equal 300
boundary f p f
atom_style full
read_data data.2G
neighbor 2.0 bin
neigh_modify delay 5
#Potential function
pair_style airebo 2.5
pair_coeff * * E:/lammps/CH.airebo C
#Mass
mass 1 12.081
#groups & heat layers
group HOT molecule 1
group COLD molecule 2
group Leftbound molecule 3
group Rightbound molecule 4
group total subtract all Leftbound Rightbound
compute Thot HOT temp
compute Tcold COLD temp
compute Ttotal total temp
compute kinetic all ke
compute potential all pe
variable thot equal c_Thot
variable tcold equal c_Tcold
variable totalenergy equal c_kinetic+c_potential
#Timestep
timestep 0.001
fix LB Leftbound setforce 0 0 0
fix RB Rightbound setforce 0 0 0
#Initial condition: System is at 300K
velocity total create $T 798456 dist gaussian
#1st Equilibrium, NH
fix 1 total nvt temp $T $T 50
thermo_style custom step c_Tcold c_Thot c_Ttotal
thermo_modify lost warn
thermo 1000
dump trajectory all atom 5000 3c60tra.dump
run 400000
unfix 1
#2nd equilibrium nve
variable Th equal 330
variable Tc equal 270
fix 1 total nve
run 200000
write_restart restart.equil
fix hot HOT langevin {Th} {Th} 1 6453 tally yes
fix cold COLD langevin {Tc} {Tc} 1 12354 tally yes
#Calculation
run 500000
compute kine all ke/atom
fix spatialoutput total ave/spatial 1 20000 20000 x lower 0.025 c_kine units reduced &
file spatialT.dat
fix Delta_out all ave/time 1 1 10000 f_hot f_cold file fluxfix.dat
run 2000000
in.langevin (1.65 KB)
