Langevin Thermostat not Reaching Set Temperature
Hi Majdi,
Have to tried by changing Tdamp/damp parameter of fix Langevin ?
It is 2.0 in present script while your dt = 0.0004. I would have thought it close to
0.04-0.4 or so.
-Sanat
Dear Dr. Tiwari,
I have not tried varying Tdamp yet. I chose this value based on a paper from Professor Bowen Li’s research group, attached to this email.
I will reduce it to the suggested value and communicate the outcome.
Thank you,
Tara
Chen_MD-Simulations-HeatBathEffect_2010.pdf (666 KB)
Dear Dr. Tiwari,
I tried using a damping factor of 0.4; the thermostated region gets closer to the set values but the non-thermostated region becomes non-linear and irregular.
I believe the problem is actually my simulation time. I re-read the last reference carefully and found that their system is 3x3x10 unit cells and they let it reach steady-state over 40 ns. My system is 10x10x8 unit cells so the run is much much longer. I’ve setup a new simulation with a longer simulation time. I’ll let the community know of the outcome once it is in.
Thanks again for your input. I appreciate it.
Tara
