Hi Steve,
I have a question on the simulation with large cutoff distance. In my system, 90% atoms have the cutoff distance around 1.2 [LJ unit]. However, 10% of them have a very large cutoff distance, e.g. 10 [LJ unit].
When I use the bin size as 2.5 [LJ unit], the simulation runs very slow. Do you have any suggestions on settings for neighbor/ neigh_modify, then, I can run the simulation faster?
Thank you very much!
All my best,
Ying Li
Hi Steve,
try using neighbor list style "multi" instead of "bin".
you may also want to try out communicate style "multi"
cheers,
