Dear All,
I have a problem in the data file. I checked in pair_colloid.cpp file.
Let me reproduce some pieces:
void PairColloid::compute(int eflag, int vflag)
// loop over neighbors of my atoms
for (ii = 0; ii < inum; ii++) {
i = ilist[ii];
xtmp = x[i][0];
ytmp = x[i][1];
ztmp = x[i][2];
itype = type[i];
jlist = firstneigh[i];
jnum = numneigh[i];
for (jj = 0; jj < jnum; jj++) {
j = jlist[jj];
factor_lj = special_lj[sbmask(j)];
j &= NEIGHMASK;
delx = xtmp - x[j][0];
dely = ytmp - x[j][1];
delz = ztmp - x[j][2];
rsq = delxdelx + delydely + delz*delz;
jtype = type[j];
My question is: what are i and j variables (i=ilist[ii]; j=jlist[jj])? also inum and jnum?
May be answer is here, but I can not follow.
inum = list->inum;
ilist = list->ilist;
numneigh = list->numneigh;
firstneigh = list->firstneigh;
In this part, it is mentioned if rsq <= diameter of monodisperse particles K[0], then I should get
the error message LARGE/LARGE overlap for colloidal particles. But in my case, I am getting
the error message even though rsq> diameter.
My another question is: when the following method is executed?
double PairColloid::single(int i, int j, int itype, int jtype, double rsq,
double factor_coul, double factor_lj,
double &fforce)
Thanks for any help,
Bandy
