When I use lattice and create_atoms command create atoms for some regions, I use the following commands
#-------------------------model----------------------------
lattice fcc 0.4
region box block 0 110 0 30 0 20
create_box 2 box
#--------------------------boundary------------------------
region region_boundary_top block 0 110 0 30 0 3
region region_boundary_bottom block 0 110 0 30 17 20
#--------------------------flow zone-----------------------
region region_flow_all block 0 110 0 30 3 17
#--------------------------create atoms--------------------
create_atoms 1 region region_boundary_top
create_atoms 1 region region_boundary_bottom
#---------------------------group---------------------------
group group_boundary_top region region_boundary_top
group group_flow_all region region_flow_all
and the results is shown as follows:
46200atoms in group group_boundary_top
39600atoms in group group_boundary_bottom
13200 atoms in group group_flow_all
So my questions are
(1) why the number of atoms in ‘group_boundary_top’ and ‘group_boundary_bottom’ are not equal?
(2) Because I want to create another type atoms using ‘create_atoms random’ command in the region named ‘region_flow_all’. And I do not need to include atoms belong to ‘group_boundary_top’ and ‘group_boundary_bottom’ in ‘group_flow_all’. So what I should do? Definition a region slightly less than ‘region_flow_all’ for ‘group_flow_all’ such as ‘region region_flow_all block 0 110 0 30 3.1 16.9’? Thank you very much for your suggestions.
Best wishes,
Qiangqiang Sun
lattice fcc 0.4
20
create_box 2 box
110 0 30 0 3
110 0 30 17 20
110 0 30 3 17
So my questions are
(1) why the number of atoms in 'group_boundary_top' and
'group_boundary_bottom' are not equal?
because you have periodic boundary conditions and you chose your regions
such that atoms would be placed *exactly* on the box boundaries. LAMMPS
tries hard to not put two atoms on top of each other at locations that are
identical due to PBC.
(2) Because I want to create another type atoms using 'create_atoms
random' command in the region named 'region_flow_all'. And I do not need to
include atoms belong to 'group_boundary_top' and 'group_boundary_bottom' in
'group_flow_all'. So what I should do? Definition a region slightly less
than 'region_flow_all' for 'group_flow_all' such as 'region
30 3.1 16.9'? Thank you very much for your suggestions.
how about, you try it out and carefully visualize the results? you are the
best judge as to whether a command does produce the results that you are
looking for,
it is easy to check for overlapping atoms with delete_atoms overlap.
