Hello Andrew,
I had build a system based on the example in the moltemplate website
(Graphene, water and nanotube example).
I hope I am not spamming anyone by forwarding this conversation to the list.
That is a somewhat complicated example. I hope it was not hard to
follow. If it is helpful, here is another picture of that system,
viewed from a different angle:
http://www.moltemplate.org/images/nanotube+water/nanotube+walls+water_top_nopbc_t=0.jpg
(The system looks rectangular after periodic boundary conditions are applied
http://www.moltemplate.org/images/nanotube+water/nanotube+walls+water_side_pbc_t=0ps.jpg)
I want to begin by saying that there are several ways to build this
system. Laurent Joly posted the scripts he used to build this system
here:
http://lammps.sandia.gov/scripts.html
I wanted to create some regions in
lammps using the region command, but however I was unable to decide upon the
lattice for this system.
Could you please let me know how to specify the
lattice for the given example?
I have never used the "lattice" command, but from looking at the
documentation, I think (for graphene with C-C bond-length 1.42A) it
would be:
lattice custom 2.4595121467478 &
a1 1.0 0.0 0.0 &
a2 0.5 0.8660254037844386 0.0 &
a3 0.0 0.0 1.0 &
basis 0.0 0.0 0.0 &
basis 0.5 0.28867513459481287 0.0
Note: Grahene is a 2-D crystal,. However your simulation is in 3-D.
For this reason, I think we must include an a3 vector (even though it
is meaningless). So I used "a3 0.0 0.0 1.0" here. This was
arbitrary. Please ignore it.
Please do not be angry if this lattice command does not work. I have
not tried it.
--- Where do these numbers come from? ----
The lattice vectors for the 2-dimensional graphene sheet which I am
using are expressed (in Angstroms) in the command which creates the
wall. This information is located in the "graphene_walls.lt" file.
(http://www.moltemplate.org/examples/nanotube+water/graphene_walls.lt)
unitcells = new Graphene/2AtomCellAlignX
[14].move(1.2297560733739, 2.13, 0)
[13].move(2.4595121467478, 0, 0)
This is a hexagonal unit cell. The length of each lattice vector is
2.4595121467478 Angstroms. However, LAMMPS wants us to express the
other coordinates in units of this distance, so I divide all
coordinates by 2.4595121467478. This results in:
a1 1.0 0.0 0.0 &
The contents of each unit cell in this example were defined in
"graphene.lt" (http://www.moltemplate.org/examples/nanotube+water/graphene.lt).
The positions of the atoms in each unit cell are defined there:
2AtomCellAlignX
# atomID molID atomType charge x y z
write("Data Atoms") {
$atom:C1 $mol:... @atom:../C 0.0 -0.61487804 -0.355 0.0
$atom:C2 $mol:... @atom:../C 0.0 0.61487804 0.355 0.0
If I understand correctly, the numbers following the "basis" arguments
are the coordinates of each atom in this unit cell.
(http://lammps.sandia.gov/doc/lattice.html) We must divide them by
the lattice-cell length as well (2.4595121467478). This results in:
basis -0.25 -0.14433756729740643 &
basis 0.25 0.14433756729740643
however I offset the two positions so that they are not negative.
This resulted in:
basis 0.0 0.0 0.0 &
--- Combining this information, the result is: ---
a1 1.0 0.0 0.0 &
a3 0.0 0.0 1.0 &
basis 0.0 0.0 0.0 &
Could you please also let me know how to cite
Moltemplate?
Unfortunately I have not yet had time to published a paper on
moltemplate, but I'd like to. I will let you know if I do. Thanks
for offering to cite me!
Cheers!
Andrew
