Lattice Regarding
Hi Steve,
I am trying to create a lattice structure which has following geometry:
Primitive vectors
a(1) =   5.09000000   .00000000   .00000000
a(2) =    .00000000  6.74800000   .00000000
a(3) =    .00000000   .00000000  4.52300000
Basis Vectors:
Atom    Lattice Coordinates                Cartesian Coordinates
C    .89000000   .25000000   .45000000     4.53010000  1.68700000  2.03535000
C   -.89000000   .75000000  -.45000000    -4.53010000  5.06100000 -2.03535000
C   -.39000000   .75000000   .95000000    -1.98510000  5.06100000  4.29685000
C    .39000000   .25000000   .05000000     1.98510000  1.68700000   .22615000
Fe   .03600000   .25000000   .85200000      .18324000  1.68700000  3.85359600
Fe  -.03600000   .75000000  -.85200000     -.18324000  5.06100000 -3.85359600
Fe   .46400000   .75000000   .35200000     2.36176000  5.06100000  1.59209600
Fe   .53600000   .25000000  -.35200000     2.72824000  1.68700000 -1.59209600
Fe   .18600000   .06300000   .32800000      .94674000   .42512400  1.48354400
Fe  -.18600000  -.06300000  -.32800000     -.94674000  -.42512400 -1.48354400
Fe   .68600000   .43700000   .17200000     3.49174000  2.94887600   .77795600
Fe  -.68600000  -.43700000  -.17200000    -3.49174000 -2.94887600  -.77795600
Fe  -.18600000   .56300000  -.32800000     -.94674000  3.79912400 -1.48354400
Fe   .18600000  -.56300000   .32800000      .94674000 -3.79912400  1.48354400
Fe   .31400000  -.06300000   .82800000     1.59826000  -.42512400  3.74504400
Fe  -.31400000   .06300000  -.82800000    -1.59826000   .42512400 -3.74504400
However, while i write the following in LAMMPS, it shows errors to read the negative basis vectors:
lattice custom 2.55 a1 5.09 0 0 a2 0 6.748 0 a3 0 0 4.523 origin 0.0 0.0 0.0 basis 0.89 0.25 0.45 basis **-**0.89 0.75 0.45 basis -.39 .75 .95 basis .39 .25 .05 basis 0.036 0.25 .852 basis **-**0.036 0.75 .852 basis 0.464 0.75 .352 basis 0.536 0.25 .352 basis 0.186 0.063 .328 basis **-**0.186 0.063 .328 basis 0.686 0.437 .172 basis **-**0.686 0.437 .172 basis 0.186 0.563 .328 basis 0.186 0.563 .328 basis 0.314 0.063 .828 basis **-**0.314 0.063 .828
create_atoms 2 region workpiece basis 1 1 basis 2 1 basis 3 1 basis 4 1 basis 5 2 basis 6 2 basis 7 2 basis 8 2 basis 9 2 basis 10 2 basis 11 2 basis 12 2 basis 13 2 basis 14 2 basis 15 2 basis 16 2
The basis values all have to be from 0-1 to place
atoms inside your unit cell. I imagine you can convert
your negative values to positive ones that place
the atom in the same position in the overall lattice.
Hi Steve,
Writing this even is showing errors:
lattice custom 1 a1 3.878 0 0 a2 0 3.878 0 a3 0 0 3.878 origin 0.0 0.0 0.0 basis 0 0 0 basis 1 0 1 basis 0 0 1 basis 1 0 0 basis 0 1 0 basis 1 1 0 basis 1 1 1 basis 0 1 1 basis 0.5 0.5 0 basis 0 0.5 0.5 basis 1 0.5 0.5 basis 0.5 0.5 1 basis 0.5 1 0.5 basis 0.5 0.5 1 basis 0.5 0.5 0.5
Regards,
Saurav
The lattice doc page states:
Via the {basis}
keyword you add atoms, one at a time, to the unit cell. Its arguments
are fractional coordinates (0.0 <= x,y,z < 1.0), so that a value of
0.5 means a position half-way across the unit cell in that dimension.
Change your 1s to 0s. It means the same thing.
In fact having 2 entries for (0,0,0) and (0,0,1) would put
two atoms on top of each other. So your input doesn't make sense.
