Hello!
Just a quick question: does lb thermostat implemented in lammps provide thermalization of the rotational degrees of freedom?
Is it capable of modelling rotational diffusion?
Dimitry
Hello!
Dimitry
Hello!
can you be a bit more specific, i.e. which command you are
specifically referring to?
also, what individual commands in LAMMPS can do is specified in the
individual pages of the documentation. if it doesn't say that it does
something, you can assume that this feature is not available.
please also note, that if you are asking about a specific package,
i.e. it looks like you are asking about the USER-LB package, then you
may be better off to send a specific inquiry to the authors of the
package, as especially "user" packages are supported by their
respective authors. contact details should be in the corresponding
README files.
