Hello!
I am needing to compile and install OpenKIM on the High Performance Computing Virtual Lab (HPCVL).
I appeared to have success in installing OpenKIM in my home directory, but when I ran the OpenKIM example tests, I consistently get the following error in all tests:
/usr/lib64/libgfortran.so.3: version GFORTRAN_1.4' not found /usr/lib64/libstdc++.so.6: version
GLIBCXX_3.4.15’ not found
/usr/lib64/libgfortran.so.3: version `GFORTRAN_1.4’ not found
I have /usr/lib64 in my PATH, but that did not fix the above errors. I was wondering what you might recommend.
Thank you,
Josh
