Hi! I tried that as my first response to the problem, and upgraded to the version I mentioned, but didn’t seem to solve the issue.
Here is the traceback, in case it is needed:
MPRestError Traceback (most recent call last)
omissis/MP_query.py in <module>
36 theoretical = {
37 str(d.material_id): d.theoretical
----> 38 for d in mpr.summary.search_summary_docs(
39 material_ids=ids, fields=["material_id", "theoretical"]
40 )
~\miniconda3\envs\mp_update\lib\site-packages\mp_api\routes\summary.py in search_summary_docs(self, material_ids, formula, chemsys, elements, exclude_elements, possible_species, nsites, volume, density, crystal_system, spacegroup_number, spacegroup_symbol, deprecated, total_energy, formation_energy, energy_above_hull, equilibrium_reaction_energy, uncorrected_energy, is_stable, band_gap, efermi, is_gap_direct, is_metal, magnetic_ordering, total_magnetization, total_magnetization_normalized_vol, total_magnetization_normalized_formula_units, num_magnetic_sites, num_unique_magnetic_sites, k_voigt, k_reuss, k_vrh, g_voigt, g_reuss, g_vrh, elastic_anisotropy, poisson_ratio, e_total, e_ionic, e_electronic, n, piezoelectric_modulus, weighted_surface_energy, weighted_work_function, surface_energy_anisotropy, shape_factor, has_reconstructed, has_props, theoretical, sort_fields, num_chunks, chunk_size, all_fields, fields)
264 }
265
--> 266 return super().search(
267 num_chunks=num_chunks,
268 chunk_size=chunk_size,
~\miniconda3\envs\mp_update\lib\site-packages\mp_api\core\client.py in search(self, num_chunks, chunk_size, all_fields, fields, **kwargs)
799 # documented kwargs.
800
--> 801 return self._get_all_documents(
802 kwargs,
803 all_fields=all_fields,
~\miniconda3\envs\mp_update\lib\site-packages\mp_api\core\client.py in _get_all_documents(self, query_params, all_fields, fields, chunk_size, num_chunks)
848 chosen_param = list_entries[0][0] if len(list_entries) > 0 else None
849
--> 850 results = self._query_resource(
851 query_params,
852 fields=fields,
~\miniconda3\envs\mp_update\lib\site-packages\mp_api\core\client.py in _query_resource(self, criteria, fields, suburl, use_document_model, parallel_param, num_chunks, chunk_size)
292 url += "/"
293
--> 294 data = self._submit_requests(
295 url=url,
296 criteria=criteria,
~\miniconda3\envs\mp_update\lib\site-packages\mp_api\core\client.py in _submit_requests(self, url, criteria, use_document_model, parallel_param, num_chunks, chunk_size)
399 ]
400
--> 401 initial_data_tuples = self._multi_thread(
402 use_document_model, initial_params_list
403 )
~\miniconda3\envs\mp_update\lib\site-packages\mp_api\core\client.py in _multi_thread(self, use_document_model, params_list, progress_bar)
602
603 for future in finished:
--> 604 data, subtotal = future.result()
605 if progress_bar is not None:
606 progress_bar.update(len(data["data"]))
~\miniconda3\envs\mp_update\lib\concurrent\futures\_base.py in result(self, timeout)
436 raise CancelledError()
437 elif self._state == FINISHED:
--> 438 return self.__get_result()
439
440 self._condition.wait(timeout)
~\miniconda3\envs\mp_update\lib\concurrent\futures\_base.py in __get_result(self)
388 if self._exception:
389 try:
--> 390 raise self._exception
391 finally:
392 # Break a reference cycle with the exception in self._exception
~\miniconda3\envs\mp_update\lib\concurrent\futures\thread.py in run(self)
50
51 try:
---> 52 result = self.fn(*self.args, **self.kwargs)
53 except BaseException as exc:
54 self.future.set_exception(exc)
~\miniconda3\envs\mp_update\lib\site-packages\mp_api\core\client.py in _submit_request_and_process(self, url, verify, params, use_document_model)
670 message = str(data)
671
--> 672 raise MPRestError(
673 f"REST query returned with error status code {response.status_code} "
674 f"on URL {response.url} with message:\n{message}"
