Limited or No output in log file due to variable formula
Dear Steve, Users,
I have a input script in which I am updating the coordinates of the atoms in a certain way. It has to be done iteratively for several steps. The minimal steps in the script are as follows
Dear Steve, Users,
While, there is no error, my log file is getting huge because of all the
variable calculations lines it writes. As I am calculating 'z' values for
each atom at multiple steps, the following portion is written for each atom
for each timestep in the log file. Is there a way to supress that or some
other workaround?
try "echo none" or "-echo none" at the command line.
Thanks Axel…
-echo none worked.
One more help if possible.
As you can see from the script snippet above, as I am changing the z coordinates of the atoms individually, I am also getting following lines “natoms” times even after I put -echo none in the command line.
“1 settings made for z”
Is there a way to suppress that?
Vikas
Thanks Axel..
-echo none worked.
"natoms" times even after I put -echo none in the command line.
"1 settings made for z"
only via "log none", which will turn off writing to the log file entirely.
One the other hand, there is always a possibility to turn any output off in the source code.
Regards,
Oleg.
if you down this lane, it might be even more attractive to have a "log
pause" and "log continue" command and the same for screen to suspend
output and re-enable. that would allow people to have their cake *and*
eat it.
It's almost the same as log none/log, I think. Isn't it?
24.09.13, 23:11, "Axel Kohlmeyer" <[email protected]>":
no. log none will close the file and then upon re-opening it will be
truncated. the alternative would be to add an append option.
in fact, that would be much easier to do. i think, i'll just do it and
send it to steve later... :wink:
That's why there was "almost". Agree.
Thank you guys for the suggestions. I was planning to comment out the line in the source code. I will wait for Axel’s update then and download the patch.
Regards,
Vikas
in the source code. I will wait for Axel's update then and download the
patch.
here you are. pretty simple, but effective.
enjoy,
lammps-log-append.diff.gz (974 Bytes)
Thanks Axel,
I worked. However, I did not get why you added additional class in class FixRespa:
Best Regards,
Vikas
Thanks Axel,
FixRespa:
that was an oversight. some leftover code from a debugging session.
